HF Manifold on D16Z6 engine
I <3 Hikki Chan!
will the HF exhaust manifold fit on a D16Z6 head? reason being is that i saw an adapter to fit a T25 turbo onto the HF manifold...any thoughts?
I <3 Hikki Chan!
okayy...
say i did get an HF manifold, T25 turbo and the adapter flange...what else do i need...downpipe, BOV, fuel management, I/C(?), various gauges...what else??
卐 Walnuts
blah junkyard turbo kits should only costt you 250 max, ill send you the link later after i get it from my friend, for the IC you use a 300zx stock side mount or or something else thats stock..all the piping they tell you to use ghetto hoses from home depot or something like that, i forgot about the rest
Eat a ding ding...
Originally posted by B18A1Integra
You need a waste gate and tap ur engine for turbo
and may be some new pistons so ur pistons or engine block will crack.
I <3 Hikki Chan!
well i don't want it to be too ghetto...just functional for about 6psi...would i need to upgrade the fuel pump for 6lbs? or is that just to be on the safe side...see i know a lot about DSMs...but boosting the d16z6 is new to me...so lemmie know what i should do...i haven't been able to find any information on turbo setups using the hf manifold...yet
