help, tranny fluid leaking
so i'm looking at my driveway and i see a small puddle of tranny fluid.
i put the car on jackstands and find that the shift linkage is leaking. when you shift through the gears it gets worse.
is there something i can tighten or seal?
Re: help, tranny fluid leaking
i've been googling to see if i could just buy some new seals/bushings, but can't seem to find anything online.
anyone know how i can fix this problem?
You can buy that seal just the same as anything else for your car. You just need to find someplace where you can find a part number and order it..
Sumospeed #O.G.
Any honda dealership should be able to help you out with purchasing the part. Not sure if you have to open the tranny up to replace the seal though.
civic/b16/ y21 hydro tranny
thanks dorko.
not to mention my p/s pump is now leaking.. not a problem though i'll eventually remove it once i go boost
thanks dorko.
