help with overheating
can the water pump be the issue of why my car wonts to overheat i seen where integra timing belt and waterpump should be replaced around 90k and im alomst at 92k now and the water pump is now leaking at the weep hole but it wasn't before and it was still overheating.
do u think it was the water pump the whole time ?
Re: help with overheating
ok so it must have been the problem the whole time huh? its been overheating or fluctuating for a week or so then yesterday the waterpump fiannlly went out and is leaking antifreeze threw the weep hole or w/e its called
don't go and replace random parts and try to get lucky. troubleshoot the biotch. first make sure you bleed all the air out of the system. check and see if the fans are running or not. these are a few things to check for first.
