HELP! no fire on 90 hatchback
Old 07-29-2007, 06:18 PM
96LsIntegra's Avatar
96LsIntegra has disabled reputation
Default HELP! no fire on 90 hatchback
ok i jus got a 91 civic DX i went to start it and it cranks over but wont start checked to see if gettin any fire, nothin so i had a new distributor put that on, and still no fire then my friend told me to change the main relay, did that still nothing, then pulled my friends ECU out of his car and that did not work,
so im gettin pissed about it,
someone let me know somthing
thanks
im not goin to be on here somone that knows what there talkin about call me anytime tonight
540-330-5788
96LsIntegra is offline
Old 07-29-2007, 06:21 PM
important's Avatar
important is an unknown quantity at this point
Default Re: HELP! no fire on 90 hatchback
plug wires?haha
is it still stock harness or converted to mpfi?
and is your main fuel relay good,im not positive but if its not sending fuel it wont give spark?
important is offline
Old 07-29-2007, 06:23 PM
it has new wires,
yboost's Avatar
yboost is an unknown quantity at this point
Has the car been sitting ?? If so check fuel pump
yboost is offline
Old 07-29-2007, 06:35 PM
90singleslam's Avatar
90singleslam has disabled reputation
make sure the timing belt is good...same thing happened to a friend like a month ago did all the same stuff........
90singleslam is offline
Old 07-29-2007, 06:45 PM
yeah timing is good, yea it been parked since 02
Old 07-29-2007, 06:51 PM
bluetig757's Avatar
bluetig757 has a little shameless behaviour in the past
i believe that car has two regular fuses that could do that.
bluetig757 is offline
Old 07-29-2007, 06:58 PM
u check the fuse for the ecu in the engine bay?and when u turn the key to the second click before starting do u hear the fuel pump humm for a sec and ur check engine light come on and go off simultaneously
Old 07-29-2007, 07:07 PM
yboost's Avatar
Yeah i agree with him, make sure u hear the click when u turn the key. If u dont hear a click , Check fuel pump. Since it has been sitting since 02 it might need plugs, fuel pump, lil shit like that.
yboost is offline
Old 07-29-2007, 09:08 PM
ok dont ask me wtf it was but i kept turning it on and off and somthing clicked the the lil red light came on the ecu and then it started, but now the fuel pump is not workin so im goin to change out the gas tank and pump, dose have old gas in it, well see what happins after that
And thanks alot with all the help
