Help My MAF wont read over 2500RPms.....
Formerly Shinobi....
What the hell is wrong with it? I was told my CAI might have made my MAF quit workin but that doesnt make sense cause if my MAF quit workin I wouldnt be in safe mode I wouldnt be runnin at all........Right?
I dunno ima take the CAI off and put it back to stock so I can get warranty on it........The friggin MAF is 800$'s , dont believe me? Call Nissan and find out.......
Oh its a 2002 SpecV
I wasnt even gettin on it when this happened......
Dunno why it happened.....
Fug it i'll figure it out soon enough.....
Please if you have any (Realative) advice please share.....
-Jeff
Oh its a 2002 SpecV
-Jeff
¿Señor Member?
warranty that pos, and yes it is possible your car will run even if it is screwed. My car runs fine up to about 10psi with the maf not plugged in. Don't ask. I put a cai on a wrx and accidently reversed the maf while mounting it, and the car wouldn't run. I guess it could go either way depending on the car. Is it a hotwire type maf?
NM guys Im just gonna get it warranteed, I was gonna fix it my self becaue i was gonna be lazy so i didnt have to take the CAI off and put the fishbowl back on.....
im not really familiar with nissans. the only nissan MAF ive ever seen was tiki's and the one i had on my s13 that i pulled the motor out of, but a quick MAF fix is to take some Brakleen and spray it on the sensor wires in the middle. then take some electrical contact cleaner (~$10 from radio shack) and spray it on both the MAF side and wiring harness side of the connection. how do you know it stops reading after 2500rpms? id think a service engine light would pop on if the MAF was not working. does it only cut on after 2500RPMs? fill us in on how you came to that conclusion. good luck
and you seriously need some help or a hookup at a dealership if youre paying $800 for a MAF sensor
LMAO
J/P
-Jeff
a buddy of mine put a short ram injen on his 2000 altima.....same shiz happened.....is it only nissans and wrx's have maf sensors?...what are they for...(sorry im not a nismo freak)
no most engines use mass air flow sensors. i just dont think honda uses them. i know my chevy does, so did my nissan. so do most fords. they measure the amount of air being pushed through them and make small adjustments accordingly to the amount of fuel being dumped into the motor. theyre kind of a pain in the ass because they can cause some weird conditions when you modify the car. theyre kind of restrictive, but if you port them your a/f goes all to hell (sometimes) and its harder to tune.
