HELP!!!!! HATCH WONT GO INTO GEAR!!
I have a 94 civic si hatch that wont go into gear when car is running. Recently changed the clutch master and slave about a month ago. Been driving the car for the past month and even today. Then today i get home and try to go back out and the car doesnt get into gear. Can start it up fine. Turn it off and press the clutch in and go thru every gear. Fine. Press clutch in to start. and works fine, but press clutch in to go to first and nothing. Feels like something blockin the gear. IDK. Let me know what you think. Need to fix ASAP.
Was thinkin that the clutch pedal switch went bad. Can it go bad? Anyone heard of that. Shit, IDK.
Thanks for the help!!!!!
baller/dickbutt#69
Re: HELP!!!!! HATCH WONT GO INTO GEAR!!
i am 10000000000000% sure you need to replace the clutch same thing happened to me, its not the fluid or nothing of that sort trust me and also you might as well change the flywheel to
NAZI mod
