Help with Gas Leak
Old 08-16-2012, 05:49 AM
Irubonrights's Avatar
Irubonrights has disabled reputation
Default Help with Gas Leak!?!?!?!?!
I have 91 civic that is still dpfi i have a gas leak coming from one of the fuel lines leading to the intake manifold. I used the correct bolt but when i try the bolt it one strips the bolt .. My Question is Am I missing a special washer or something? and could this be why my carwont start...Im not throwing any engine codes
Irubonrights is offline
Old 08-17-2012, 05:14 AM
Default Re: Help with Gas Leak
bump for picture added of what im talking about
Old 08-17-2012, 05:40 AM
i pooped a squirrel
Gen_Crunchytoes's Avatar
Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes
You should have a copper crush washer on that bolt. But it wont cause it to not start. What happens when you try to start the car
Gen_Crunchytoes is offline
Old 08-17-2012, 05:57 AM
it cranks but will not start up and gas squirts everywhere
Old 08-17-2012, 07:27 AM
i pooped a squirrel
Get the washer you need from honda and go from there. Post results
Old 08-17-2012, 07:30 AM
Digital Life
83Stang5.0's Avatar
Yea that washer is what you need. I've seen some seal without them before, but it's better to just get the washer and not worry about possibly stripping it from overtightening.
83Stang5.0 is offline
Old 08-17-2012, 08:53 AM
thanks for the help I have that fixed now I didnt go the washer route... but it worked.... now it still wont start im thinking no gas maybe
Old 09-15-2012, 03:29 AM
00_civic757's Avatar
00_civic757 has disabled reputation
check ur fuel pressure regulator
00_civic757 is offline
LXative
12-13-2010 02:24 PM
aec07716
05-25-2010 10:21 AM
solocrxcivic
09-07-2006 12:28 PM
scubaskim
12-19-2002 05:52 AM
B18Tuner
12-12-2002 02:02 PM
Quick Reply: Help with Gas Leak
