help d16y7into a 90 crx hf
your mom says hi!!!!
a friend of mine is trying to put a d16y7 in a 1990 crx he has the motor trans ecu does he needs anything else cuz he needs this done by friday any help would be appricated
corona connessuer
you use the stock tranny and intake and harness youll have to switch the motor mount and the lower pulley. i put one of these motors in a 89 crx
he is on here. noreverse
you cant use the tranny, ecu or the harness that comes with the d16y7
sumospeedDOTcom
yep he put one in my car. near the same specs as the si motor so no real performance difference, however if i ever get around to buying a new y8 head the bottom end should be stronger and has way less miles. and besides, my car is an 88!
