HELP: Clutch issue
Old 04-05-2009, 06:08 PM
SYCKDC23's Avatar
SYCKDC23 has disabled reputation
Default HELP: Clutch issue
I got an integra gsr with stage 3 exedy, i have to push the clutch all the way to the floor to switch gears. Theres way to much play in the pedal. How can I tighten this up so the car starts to move when letting out at the top.
Does this involve bleeding the master cylinder?
SYCKDC23 is offline
Old 04-05-2009, 06:26 PM
wierdguy75's Avatar
wierdguy75 has disabled reputation
Default Re: HELP: Clutch issue
You could try bleeding the master cylinder, but make sure you bleed the clutch slave cylinder too.
wierdguy75 is offline
Old 04-06-2009, 08:30 AM
00civicman's Avatar
00civicman is infamous around these parts00civicman is infamous around these parts00civicman is infamous around these parts00civicman is infamous around these parts00civicman is infamous around these parts00civicman is infamous around these parts00civicman is infamous around these parts00civicman is infamous around these parts00civicman is infamous around these parts00civicman is infamous around these parts00civicman is infamous around these parts
id suggest the same
00civicman is offline
Old 04-06-2009, 02:20 PM
Al_P's Avatar
Al_P has disabled reputation
It is not likely bleeding will help unless you opened the system recently.
Crawl under the dash and look up where master is. You will see a rod going to the clutch pedal. There is a 12mm nut on it. brake it loose and adjust the pedal play by turning rod in or out of the clutch pedal.
Al_P is offline
Old 04-06-2009, 04:53 PM
small town guy
broke_honda's Avatar
broke_honda has disabled reputation
x2
broke_honda is offline
Old 04-09-2009, 12:22 AM
SYCKDC23's Avatar
its wierd though, it tightens up as I drive
SYCKDC23 is offline
DAinteg91
01-28-2008 01:07 PM
gsr-turd
10-30-2007 05:07 PM
Qwiksillva
04-28-2005 10:14 AM
Quick Reply: HELP: Clutch issue
