HELP: Brake lights not working
Ok Guys...When i push down on the brakes the lights don't turn on but the crazy thing is when i turn on the lights it comes on. When the lights are on and i push down on the brakes it doesn't turn on. I check ALL the fuses and they where good. NEED HELP!!
for alarms/rmt-strts
Re: HELP: Brake lights not working
take a multi meter/test light to see if your getting 12v at the switch. tail lights and brake lights are on a different fuse on just about every vehicle as a fail safe for if you blow the more commonly blown fuse (tail light) but yea if its a honda i believe its a green wire with a white tracer at the switch
