HELP!!! AUTOMATIC TO MANUAL TRANNY CONVERSION
I have a automatic 91 Acrua Legend and am interested in converting it to a manual. Please post any information on how and where I can get this done, or a list of parts that I will need. Thank you.
Re: HELP!!! AUTOMATIC TO MANUAL TRANNY CONVERSION
its a 91 legend, unless its in MINT condition, its not worth the hassle. seriously. just wait till you find out what exactly is involved.
Speak&Spell Anyone?
pedal assembly, some wiring needs to be changed, you need to change over the ingiton switch so the key doesn't get stuck in the ignition (due to it not being in park). console, ecu (which should be very hard to find for a reasonable price), transmition (which should also be hard to find and will be very expensive) cluster (not required) linkage (which will also be hard to find)
This isn't like a civic or an integra, you don't have as many parts with easy access. I wouldn't recommend doing it. he happy the car is an auto ad buy a project 5 speed.
you are able to modify the wiring to not have the ignition switch stick when you are not in park. But you did forget about the diff and possably axels.
