HELP ASAP
can someone tell me if ill pass inspection with the srs light on, and if i cant pass how can i reset it, its a 1996 eclipse
Re: HELP ASAP
no u will not, srs = airbag. i actually have a srs sensor that i purchased for the same reason but never actually used it if your interested.
Re: HELP ASAP
no you wont pass and take the bulb out so its not lit up anymore
Re: HELP ASAP
Also, depending on what car you have you can get a JDM guage cluster and just install that because most of them don't have a SRS light on them. I know mine didnt on my Teg and my EG
Re: HELP ASAP
there has to be a way to reset it, or a cheap shop
Re: HELP ASAP
What kind of car?
Re: HELP ASAP
96 eclipse
Re: HELP ASAP
You reset it by fixing the problem. The SRS system does a self check on power up and throws a fault if there is a problem. It isn't like an OBD2 ECU where the codes will be stored.
Re: HELP ASAP
and taking the bulb out wont fly unless its a lazy ass inspector...cause the srs light will not probe out when the key is turned on....it is supposed to fail
Re: HELP ASAP
if its throwing out any codes you can just go to auto zone and see if you can borrow a scanner and delete the codes yourself...temporarly that is..
| All times are GMT -8. The time now is 07:15 AM. |
