Also, depending on what car you have you can get a JDM guage cluster and just install that because most of them don't have a SRS light on them. I know mine didnt on my Teg and my EG
You reset it by fixing the problem. The SRS system does a self check on power up and throws a fault if there is a problem. It isn't like an OBD2 ECU where the codes will be stored.
and taking the bulb out wont fly unless its a lazy ass inspector...cause the srs light will not probe out when the key is turned on....it is supposed to fail
