headlight issue
im having an issue with my passenger side low beam light. check the bulb and that wasnt the problem. checked the under hood fuse no problem. under dash fuses no problem. the high beam works fine just not the low beam. brand new bulb same thing. any input on what i should check next?
Im having the same problem with my driver side. Its on a 90 240sx. I used a voltmeter. Everything has power, but I think the drive lights lost its ground. Traced it back to the relay box. There is continuity from the ground connector to a few different relays (albeit they all deal with the headlight in some way shape or form). Any ideas? Sorry to hijack your thread OP. Maybe it will help both of us?
If there are separate headlight relays for the left and right sides, it could be wiring or a relay. If there is a shared relay for the left and right sides, it must be a wiring problem (or something equally as simple like a broken/corroded bulb socket. Basically if both headlights get power from the same place, and one headlight is getting power, obviously the problem is between the (non-functioning) headlight and the source of power.
A multimeter will tell you everything you need to know.
just a thought...there is a black box in driver side kick panel that is your H/L CONTROL ASSY. that could have gone bad. try find some at junkyards and swapping it out...see if that changes.
i sold the last 2 i had on ebay last week, but this is what they look like.
like i said...dont know if thats your issue.
for example...there is also a white box down in that area too. if that goes bad your gauge cluster does not illuminate.
