h23 blue top help?!
Old 08-16-2011, 10:19 PM
Hinesbk23's Avatar
Hinesbk23 has disabled reputation
Default h23 blue top help?!
I got a h23a vtec motor to put in my 95 h22a1 vtec car. I would like to relpace the timing belt water pump and oil pump but I'm not sure what pumps to get or what belt. I'm trying to keep the motor as an obd1 motor.
Hinesbk23 is offline
Old 08-17-2011, 03:12 AM
Default Re: h23 blue top help?!
None of those things have anything to do with the OBD generation. Get the pumps and belts for the engine that will be in the car.
Old 08-17-2011, 03:49 AM
Hinesbk23's Avatar
So your saying I can get a H23A vtec -blue top- at my local auto parts store?
Old 08-17-2011, 03:52 AM
Hinesbk23's Avatar
This motor was only only sold in Japan
Old 08-17-2011, 03:54 AM
Well, there should be a source for the parts you need. If there isn't, you shouldn't have bought that engine if you're unable to do basic maintenance on it in this country.
Old 08-17-2011, 03:58 AM
RIP DRAGVA-2016
NasTHatch's Avatar
being sold in japan has nothing to do with it....a JDM water pump is the same thing as a usdm water pump..
NasTHatch is offline
Old 08-17-2011, 07:33 AM
Hinesbk23's Avatar
I know the parts are the same but I'm asking what h22 do I take the parts off of. The h22a1 h22a4? I just would like to replace the timing belt water pump and oil pump why the motor is out of the car
Old 08-17-2011, 10:10 AM
hondaslutt's Avatar
hondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these parts
everything is the same except the timing tensioner. hit up google. its your friend.
hondaslutt is offline
Old 08-17-2011, 07:12 PM
Hinesbk23's Avatar
I did but there is so many threads and people not really knowing what it is. I found one though it souds like all the timing, pumps and b belts are the same as the h22a4
Old 08-25-2011, 08:45 PM
All Gold Everything
Trinidad James's Avatar
Trinidad James Trinidad James Trinidad James Trinidad James Trinidad James Trinidad James Trinidad James Trinidad James Trinidad James Trinidad James Trinidad James
go on preludepower.com and search you will find what you need.
Trinidad James is offline
Quick Reply: h23 blue top help?!
