GT500 no-start issues.
Old 10-27-2014, 05:04 PM
±RepLegion
92_SR20's Avatar
92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20
Default Re: GT500 no-start issues.
Originally Posted by Lord Humongous View Post
You got a BAP?
Yes. Fuses for the BAP are good and I checked for any exposed wiring that might have been shorting anything out back there. I'll be doing voltage checks for the BAP and checking the FPDM tomorrow.
92_SR20 is offline
Old 10-28-2014, 10:42 AM
±RepLegion
92_SR20's Avatar
Car is running, not sure what did the trick but I did quite a bit this morning before attempting to start it ( I know, I know, I should have ruled shit out but I was in a groove =/ ).
1) Checked all plug gaps / plugs for damage.
2) Changed out fuel pump related fuses, they all checked out good but I did it for good measure.
3) Checked BAP voltage/wiring for anything that may be exposed.
4) Swapped out the fuel pump / IC pump relays.
5) Reloaded my tune.
I'm sure I'm forgetting some things, has been idling in my driveway for 5-10 minutes now, going to let it go a bit longer before I try and take it anywhere.
92_SR20 is offline
Old 10-28-2014, 11:43 AM
Reloading the tune may have wiped out any short and long term trims that might have caused the problem. Might just be running too rich with the learned trims and the extra cold idle enrichment with the cooler weather. Does it have hot-start problems also?
Old 10-28-2014, 12:56 PM
±RepLegion
92_SR20's Avatar
Negative on the hot start issues.
92_SR20 is offline
Old 11-09-2014, 05:49 AM
Standartenführer
euthorus's Avatar
euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus
Will it start from a roll ? Hows the timing ?
euthorus is offline
Old 11-11-2014, 08:01 AM
Don't quit!
Somalia's Avatar
Somalia Somalia Somalia Somalia Somalia Somalia Somalia Somalia Somalia Somalia Somalia
My thought also.
Somalia is offline
Old 12-03-2014, 03:55 PM
RandomTask's Avatar
If it happens again, do the following:
1.) Turn ignition into run position, BUT DON'T CRANK. Expose the shrader valve on the fuel rail and press it to see if there's fuel pressure in the rail. Clean up any fuel that may have spilled out. If there is spark, proceed to 2 otherwise you're having a failure in your pumps.
2.) Take an extra spark plug and install it on one of the coils; Put against the engine or something grounded, get someone to crank, and see if its sparking. If its not firing at all, its something with your ignition that's preventing EVERYTHING from firing. Notably, probably your crank or cam position sensor.
RandomTask is offline
Old 12-03-2014, 04:49 PM
±RepLegion
92_SR20's Avatar
There are no schrader valves on a GT500, stupid - I know. I didn't test spark because I didn't have an extra set of hands handy the times I was playing with it, it has been running good since though.
92_SR20 is offline
Old 01-20-2015, 07:46 PM
PIZZABOY92 has disabled reputation
Sounds like and anti theft or immobilizer issue toe shouldn't be a mechanical issue with that low mileage of drive time unless it's something dumb like a soft set connector or something
PIZZABOY92 is offline
ProbeGT-ZE
10-05-2009 10:45 AM
WS6
04-21-2006 07:56 AM
Spindrift
03-31-2006 05:38 PM
cole
02-09-2006 08:10 PM
navlys32
04-27-2005 09:53 AM
Quick Reply: GT500 no-start issues.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
