gsr throttle body
Old 02-26-2009, 08:58 AM
lshonda1's Avatar
lshonda1 has disabled reputation
Default gsr throttle body
how much difference between gsr and ls throttle bodys if any
lshonda1 is offline
Old 02-26-2009, 03:16 PM
Its a Man part.
8====D's Avatar
8====D has a reputation beyond repute8====D has a reputation beyond repute8====D has a reputation beyond repute8====D has a reputation beyond repute8====D has a reputation beyond repute8====D has a reputation beyond repute8====D has a reputation beyond repute8====D has a reputation beyond repute8====D has a reputation beyond repute8====D has a reputation beyond repute8====D has a reputation beyond repute
Default Re: gsr throttle body
Im like 95% sure there bolt pattern are the same. As far as stock bore im not sure. Might try to google "GSR throttle body stock bore" same for LS and compare.... as far as throttle cable goes should be the same
8====D is offline
Old 02-26-2009, 03:20 PM
wright's Avatar
I agree that they are the same. I guess that the question is why are you asking? If you need one you can get an aftermarket one from Omni Power for under 200.00 or blox.
wright is offline
Old 02-26-2009, 03:34 PM
Its a Man part.
8====D's Avatar
Or I used a 2000 honda oydessy tb..... bolts right up to b-series.. and is 62mm bore... not huge but as big as a jdm ITR throttle body I believe and i got it for cheap... also getting your stock on ported and polished is an option... but I would go with that.
8====D is offline
Old 03-01-2009, 06:13 AM
ethendad's Avatar
ethendad has disabled reputation
how about useing a stock b16 tb
ethendad is offline
Old 03-01-2009, 06:25 AM
TurboPipingSystems
thermal's Avatar
Here, as indicated from this site:
http://hondaswap.com/reference-mater...e-chart-29095/
motor vs inside diameters (in mm)
d15b7 - 56
d16a6 - 55
d16y7 - 56
d16y8 - 56
d16z6 - 56
ZC - 55
d16a1 - 55
d16a8 - 55
b18c1 - 60
b18c5 - 62
b18a - 58
b18b - 60
b16a SiR - 58
b16a Sir2 - 60
b16a2 - 60
b16a3 - 60
b20b - 60
b20z - 60
h22a - 60
h23a - 60
f20c - 62
f22 - 60
f23 - 60
thermal is offline
Old 03-02-2009, 12:35 PM
lshonda1's Avatar
thanks
lshonda1 is offline
eXploited
01-07-2008 06:11 AM
turbo_civic01
09-23-2007 02:13 PM
Quick Reply: gsr throttle body
