gsr cooling issues!!!!
Re: gsr cooling issues!!!!
If you are having no actual problems I wouldnt worry about it. Im sure you have a pressure release radiator cap so you should be fine.
certified asshole
18psi = 1.24 bar......stock cap is rated at 1.1 bar = 16psi
as long as temp doesn't get high your fine
just make sure you don't have any air bubbles
I know Mark personally and the thing that caught my eye was the aluminum radiator is really "swollen" compared to when he put it in. Maybe you are fooling yourself, I would throw this topic up on Honda-Tech where you can get a lot more feedback. After all, the technical support on this site has kinda faded away. (no offense to anyone who offers to help). Good luck dude!
certified asshole
i like that answer
the only other thing that it could be is a HG issue or leaking sleeve
but might be one of those things you have to see in person
the psi sounds a little high(for stock) but if a diff. rad cap is on the pressure is going to be higher(IIRC, helps with cooling, raises boiling point)
