gas tank problems
Old 04-03-2009, 10:49 AM
slowrex's Avatar
slowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these parts
Default gas tank problems
well the other day when i was pumping my gas the gas starts to explode out the hole when i hold the lever down on the pump why is it comming out. the tank is not full seems like there is some air in there or summin any ideas why is doin this.
slowrex is offline
Old 04-03-2009, 04:44 PM
iwanagofast22's Avatar
iwanagofast22 iwanagofast22 iwanagofast22 iwanagofast22 iwanagofast22 iwanagofast22 iwanagofast22 iwanagofast22 iwanagofast22 iwanagofast22 iwanagofast22
Default Re: gas tank problems
turn the gas nozzle upside down.. see if that will pump normally.
iwanagofast22 is offline
Old 04-04-2009, 04:42 AM
look what you did!
crxrookie's Avatar
crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie
does it do this on every pump, every time?
if yes: it could be that the filler neck has gone bad
crxrookie is offline
Old 04-05-2009, 10:32 AM
slowrex's Avatar
its done it the past 2 times i had put gas in it and how do i replace that if thats the proplem if i pump it slow it wont do it tho.
slowrex is offline
Djtuner
12-14-2008 05:31 PM
92ls
09-08-2008 02:16 AM
octane
06-24-2008 08:10 AM
Spindrift
04-29-2006 12:00 PM
Quick Reply: gas tank problems
