g35 start/idle issues
Re: g35 start/idle issues
My G35 Did something crazily similar to what yours is doing; the dash went crazy, the engine lost a lot of power (missing), and would barely idle. My issue ended up being one of the coils taking a hell of a shit. I've long since sold the car but still have an extra set of coils. Welcome to have them if it helps you diagnose.
REAL SE-R
If you still have the OEM intake, check the rubber sections for cracks (air leaks behind maf). Mine was running like crap and a quick inspection found multiple cracks (air leaks) in the rubber. I wrapped it tight with some black 3M sealing tape and disconnected battery to reset ECU and all is well.
Hope this helps.
Hope this helps.
posted on da block
Plain and simple. Your ecm/ipdm got wet. Yes beware with big massive puddles. It sensed that that ecm/ipdm was disconnected therefor it went into limp mode. Now your car might need a few relearn procedures. Found here (http://g35driver.com/forums/engine-d...-g35-help.html) post #2. If anything else google on those. Yes clean your maf and throttle body. Timing is key on those procedures have a digital stop watch phone app of some sort at hand.
Anyways, car is back to normal pretty much after i reset the ECU and cleaned the throttle body/MAFS. Only thing at this point really is that the rpms will occasionally drop to 0 then spring back up to idle, and it was sometimes idle slightly high, around 750rpm, nothing serious though.
Thanks to everyone for the input.
