-   -   fuel pump problem (https://www.vadriven.com/forums/tech-talk-9/fuel-pump-problem-179471/)
ls/vtec hatch Mar 13, 2007 08:26 AM
fuel pump problem
I have a 93 hatch and my fuel pump isnt getting any power. My question is..is there a fuse that goes to the fuel pump or is it bad wiring or the computer please any advice.
CHAHONDA Mar 13, 2007 09:12 AM
Re: fuel pump problem
sounds like you have bad main relay
ls/vtec hatch Mar 13, 2007 10:21 AM
would any thing else not wr because of that relay?? and is that relay on the fuse box??
boostbyyou Mar 13, 2007 11:57 AM
hondas should have a seprate relay that doesnt run anything but the fuel pump an yes the relay should be in the fuse box if your not sure which one look under the fuse box cover an you will find a small diagram to show you which relay is which
ls/vtec hatch Mar 13, 2007 12:10 PM
thanks ill try it
