Fuel pump fuse location on Civic???
Old 02-21-2007, 10:53 AM
Uno Mas
p-stone's Avatar
p-stone p-stone p-stone p-stone p-stone p-stone p-stone p-stone p-stone p-stone p-stone
Default Fuel pump fuse location on Civic???
I need to do a compression check on my 94 civic ex, and I found that the fuse panel cover that has the diagram on it was removed before I bought the car. What pin on the fuse panel is for the fuel pump? If you happen to know what size fuse its supposed to be, that would be great too so I can defenitely make sure Im at the right pin. Thank you very much, Preston.
p-stone is offline
Old 02-23-2007, 11:18 AM
Uno Mas
p-stone's Avatar
Default Re: Fuel pump fuse location on Civic???
p-stone is offline
Old 02-23-2007, 02:59 PM
The Pro to call.
HatefulMechanic's Avatar
there is no dedicated fuel pump fuse, but you can pull the ECU fuse (31) and do the same thing.
or unhook the main relay.
or just do it without worrying and do it without disconnecting it. unless you try to check the compression for an hour by cranking on it, you will not have an issue with washing the cylinders down.
HatefulMechanic is offline
Old 02-25-2007, 03:08 PM
Uno Mas
p-stone's Avatar
Thanks
p-stone is offline
hondazccivic
09-18-2005 10:33 AM
WillsH22Accord
09-05-2005 06:06 AM
slimb
08-20-2005 06:42 AM
hatch77
09-12-2004 02:22 PM
Quick Reply: Fuel pump fuse location on Civic???
