fuel Pump dosnt prime something HELP
Old 10-18-2010, 12:10 PM
ek2009's Avatar
ek2009 can only hope to improve
Exclamation fuel Pump dosnt prime something HELP
96 civic with a 255 fuel pump..... sometime i cant hear the Fuel Pump Prime and car dosent start and somedays it drives fine i have changed the main relay.. could it be the fuel pump going bad plz HELP..................
ek2009 is offline
Old 10-18-2010, 01:44 PM
Slomar's Avatar
Slomar Slomar Slomar Slomar Slomar Slomar
Default Re: fuel Pump dosnt prime something HELP
Well its obviously the wiring or the fuel pump. Tap in the wires and check it with a multi-meter with the key set to the "on" position. If its not getting 12 volts or what ever its supposed to have, then theres your problem. If it is getting power, then its your pump
Slomar is offline
Old 10-18-2010, 02:38 PM
Could be the fuel pump fuse, could be the wiring, could be the fuel pump. Most aftermarket fuel pumps aren't really known for their quality or reliability, but it's easy enough to find out what's going on when the pump won't prime.
Old 10-18-2010, 04:28 PM
ek2009's Avatar
but it only dosnt it few times a day if the fuel pump was bad
ek2009 is offline
Old 10-18-2010, 05:06 PM
Stiff Member
Laserjock's Avatar
Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock
how about glancing over what you typed before clicking the submit button
no tech for you!
daammmiit, whatt0hell = There were a run of "fake" Walbro's a few years ago in the market. If you do some googling rather than expect a spoonfeeding of answers, you might find out more.
Laserjock is offline
Old 10-18-2010, 05:32 PM
Mirrorimg's Avatar
Mirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to all
Didnt think there was a fuel pump fuse, and if there was, I dont see it causing an intermittent issue.
I would replace the main relay first, and if that doesnt fix things, the fuel pump. These two items are more likely the culprit rather than the wiring.
Mirrorimg is offline
Old 10-18-2010, 05:38 PM
If it was an OEM fuel pump and never messed with, I would probably agree with that. However, it's an aftermarket fuel pump and it had to be installed somehow. Therefore, I don't necessarily trust the condition of the wiring any more than anything else.
Old 10-19-2010, 10:23 AM
ek2009's Avatar
So i drove last night and this morning and the car drove fine. it didnt cut off and the fuel pump prime evey time so i dont know what to say
ek2009 is offline
Old 10-19-2010, 10:40 AM
Hopefully it won't leave you stranded somewhere. It's a lot harder to troubleshoot intermittent problems if you can't replicate the conditions, so you'll have to figure out how you want to attack it.
Old 10-19-2010, 11:51 AM
certified asshole
crasy87rexsi's Avatar
crasy87rexsi crasy87rexsi crasy87rexsi crasy87rexsi crasy87rexsi crasy87rexsi
^+1
Check the connectors at the pump, from what I have seen most people are not good with crimping eyelets on wires. They don't crimp them tight enough and then it causes problems like that. But check the wiring and personally I solder all connections, meaning if I have to use spade or eyelets anywhere I crimp then solder. But this all depends on how the pump is designed. First pull the pump out and make sure no wires are loose. Or whoever put the pump in decided to run new wires and didn't make good connections.
crasy87rexsi is offline
Quick Reply: fuel Pump dosnt prime something HELP
