Fuel Problem?
Old 08-05-2008, 06:59 PM
Not-So-Fatty McFat
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC BLU CIVIC BLU CIVIC BLU CIVIC BLU CIVIC BLU CIVIC BLU CIVIC BLU CIVIC BLU CIVIC BLU CIVIC
Default Fuel Problem?
Well on the way to Wilmington this weekend my car started acting like it was starved of fuel again...if i would press on it gas i'd get nothing then it'd go...hadn't acted that way in over a month...i'd stop and turn the car off and turn it back on again and it'd run fine for about 15 miles then it'd start again. was fine on the way back...well today the problem seems to have gotten worse and the car has started to turn off
i'm figuring that the fuel pump needs replacing, i was also told that mabey it's my main relay, ignitor, or injectors...any thoughts
BLU CIVIC is offline
Old 08-05-2008, 07:02 PM
Sumospeed #O.G.
SlowLS's Avatar
Default Re: Fuel Problem?
Dizzy
SlowLS is offline
Old 08-05-2008, 07:15 PM
Not-So-Fatty McFat
BLU CIVIC's Avatar
could it be the distributor since i bought it new in June?
Old 08-05-2008, 07:23 PM
Ohhh Snap
madsteez's Avatar
madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez
Sounds like main relay or ignition coil,both could cause that if they are under a load and get hot.
But normally a bad main relay would cause a no start condition in temperatures like the ones we have been having. A bad fuel pump would also cause a no start condition unlike what you said you are having.
Sound more like a bad coil or bad igniter since it practically bogs (weak spark) then starts back up fine since the cars computer basically restarts the whole process of running the car
madsteez is offline
Old 08-05-2008, 07:46 PM
oxidejunky's Avatar
oxidejunky has disabled reputation
+1
oxidejunky is offline
Old 08-05-2008, 09:09 PM
Do You Want More?
Hondas_Only's Avatar
Hondas_Only Hondas_Only Hondas_Only Hondas_Only Hondas_Only Hondas_Only
fuel pump.... got the same problem with my teg... to lazy to fix tho... lol
Hondas_Only is offline
BlacktopDET
01-25-2009 12:02 PM
99whtneon
11-30-2007 07:15 PM
ls/vtec hatch
03-13-2007 12:10 PM
DirtyEF
10-29-2006 06:48 AM
MarkiSick
06-27-2004 07:15 PM
Quick Reply: Fuel Problem?
