fuel injectors for turbo need good advice
Old 08-08-2006, 01:10 PM
team703's Avatar
Default fuel injectors for turbo need good advice
what is peak and hold injectors with low resistance? also what do they mean by saturated injectors high resistance?
i ask this because i am doing a diy turbo kit and need to upgrade my injectors, i have never dealt with a turbo charged vehicle/motor so help is needed. I own a 94 civic withan ls motor in it, i only plan on running 7lbs until my money is right and i atleast get my other ls semi built to do good track numbers(if it ever happens), im sure i can probably run 11psi with good fuel managment but i want to feel this turbo thing out and enjoy before i get to crazy with it if my money is ever right to do anything internally. I was looking at the rc injectors and they had two different kind like i said saturated high resistance and low resistance peak and hold, i dont understand what that means. Also i traded for a set of dsm 450cc injectors and the guy said i could use my safc controller to control the fuel but should i get injectors that i need or just use the 450cc ones and he said i needed a resistor box from an early model civic.? sorry about the random questions but like i said turbo is new to me, ive ran an ls civic for 2 years now and i need more power
team703 is offline
Old 08-08-2006, 02:03 PM
sohc_mshue's Avatar
Default Re: fuel injectors for turbo need good advice
The injectors you have will work fine. Just use a resistor box like you said. Dont waste your time with an afc though. Take that money and chip your ecu and get it tuned using crome/uberdata/honda/neptune...either one will work fine.
sohc_mshue is offline
Old 08-08-2006, 05:53 PM
team703's Avatar
thanks
team703 is offline
Old 08-10-2006, 11:30 AM
wonka's Avatar
wonka is an unknown quantity at this point
good questions tho
wonka is offline
Old 08-10-2006, 11:32 AM
wonka's Avatar
i dont know about crome tho, thats what i have and finding someone that tunes that is a bitch
wonka is offline
Old 08-10-2006, 01:03 PM
sohc_mshue's Avatar
pm me. I can tune crome.
Old 08-10-2006, 04:45 PM
team703's Avatar
i have the dsm 450cc blacktop injectors, are they compatible with my obd1 harness, and can someone explain what the resistor box will do for me and how to hook it up when time comes for me to do this diy turbo project also i hope you guys arent getting irritated about these turbo questions, sorry i am a newbie to turbo and i dont trust shops to do install. dont want the ever so popular civic to get stolen but yeah any advice or knowledge you guys have please pass it on, i am probably like alot of people on this board as in doing motor swaps or suspension work and whatever else but turbo is new to me and it intimidates me but after the first then the rest are like clockwork...............I hope
team703 is offline
Old 08-10-2006, 09:48 PM
sohc_mshue's Avatar
Yes your injector clips will work. You need the resistor box because they are low impedence injectors. Basically you just have to wire it inline with your injector wires.
Old 08-11-2006, 09:51 AM
spotnormal's Avatar
spotnormal has disabled reputation
im running rc 310 inj with 13 lbs have no prob whatsoever . also how do u get chrome ? and cbr 600 inj will also work
spotnormal is offline
Old 08-11-2006, 10:05 AM
VAdriven Sponsor
slowb20civic's Avatar
slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic slowb20civic
if you ever plan on upping the boost, I have 880cc injectors for sale
slowb20civic is offline
Quick Reply: fuel injectors for turbo need good advice
