Front Camber kit Adjustment help plz ef sedan
so i just lowered my ef sedan on stock struts and coils sleeves for the time being.. i have a upper "a" arm kit with the camber arms on them. the last time i changed the upper "a" arms on my previous car and "tried" adjusting the camber i ended up throwing my alignment WAYY off lol.. my tires were wearing very unevenly and it was pulling hard to one side.. So my question is.. How can i set my camber kit myself to where it will still drive decent and not pull harder to one side than the other? is there something i can measure? or anything? im very new to this camber thing. My car isnt really wearing tires bad now.. just the inner edge of my front tires and my ball joints are gone anyways.. so im just replacing upper "a" arms with new ball joints in them and puttin the camber arms on the ends on the "a" arms.. can someone plz help with how i can set the camber kit or how to do it at all..or how i can aline my front end semi? plz help if this makes any sense..
Re: Front Camber kit Adjustment help plz ef sedan
Take it to a shop and have them do an alignment. Also if your car is too low, they will deny service since you can't fit the car on the rack.
right.. i was just wondering if there was any way i could get it close myself.. b4 taking it to shop.. apparently not..
Hellafunctional
If your alignment is off, make necessary adjustments. This will get it closer but you still need to take it to a shop and have them align it.
This method is a way to dial in the toe as close as you can without an alignment rack.
