-   -   flywheel help (https://www.vadriven.com/forums/tech-talk-9/flywheel-help-271885/)
hatch22 Jan 11, 2009 07:21 PM
flywheel help
i just blew my motor i know it sux and i need to replace the clutch but i have an aftermarket clutch master flywheel a friend of mine told me i couldnt get it turned and there is an insert that i need to buy please let me know if i can get it turned by a professional pm me for info
Fabrik8 Jan 11, 2009 08:51 PM
Re: flywheel help
Which one is it? If you have a solid (chromoly for example) flywheel, you can get it turned if you keep the proper step spec on it (if necessary for your engine). If you have an aluminum flywheel, they have a steel friction face and will often need to be replaced. You should be able to get in touch with Clutch Masters and see what they recommend if you just need a light resurfacing.
4door_GSR Jan 12, 2009 05:49 AM
Re: flywheel help
take it to a machine shop they can turn it and get it resurfaced
hatch22 Jan 12, 2009 10:02 AM
Re: flywheel help
thnx guys ill take it around and see what they say
