flywheel help
Old Jan 11, 2009 | 07:21 PM
hatch22's Avatar
hatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these parts
Default flywheel help
i just blew my motor i know it sux and i need to replace the clutch but i have an aftermarket clutch master flywheel a friend of mine told me i couldnt get it turned and there is an insert that i need to buy please let me know if i can get it turned by a professional pm me for info
Old Jan 11, 2009 | 08:51 PM
Default Re: flywheel help
Which one is it? If you have a solid (chromoly for example) flywheel, you can get it turned if you keep the proper step spec on it (if necessary for your engine). If you have an aluminum flywheel, they have a steel friction face and will often need to be replaced. You should be able to get in touch with Clutch Masters and see what they recommend if you just need a light resurfacing.
Old Jan 12, 2009 | 05:49 AM
4door_GSR's Avatar
4door_GSR has disabled reputation
take it to a machine shop they can turn it and get it resurfaced
Old Jan 12, 2009 | 10:02 AM
hatch22's Avatar
thnx guys ill take it around and see what they say
Bad4life2000
Jan 3, 2009 03:17 PM
oxsleeperxo
Jan 18, 2005 11:28 PM
