Flushing radiator/cooling system?
Old 01-06-2006, 05:10 PM
IRR0MPIBLE's Avatar
IRR0MPIBLE has disabled reputation
Default Flushing radiator/cooling system?
Either my radiator or hoses are leaking coolant slowly so I bought this stuff called "Stop Leak"...the directions say to flush the system and refill it with fresh coolant before pouring the stop-leak in....thing is, I don't know how to go about flushing the system...
help anyone?
IRR0MPIBLE is offline
Old 01-06-2006, 06:02 PM
Ej8D16y8-T's Avatar
Ej8D16y8-T is an unknown quantity at this point
Default Re: Flushing radiator/cooling system?
pressure test it, then look for a leak. And if you're still going to flush it there should be a screw or somthing on the bottom of the radiator. And when pouring in the new coolant, use the funnel thing to make sure you dont have any air bubbles
Ej8D16y8-T is offline
Old 01-06-2006, 06:29 PM
holla
j4k3's Avatar
come to my work, we do coolant flushes. it costs like around 60 bucks but you can get a discount if you say you know me
j4k3 is offline
Old 01-06-2006, 08:03 PM
FastCrxVaWLude's Avatar
FastCrxVaWLude is an unknown quantity at this point
well 1st off you pretty close. theres a screw ontop of the thermistat. its a relieve valve. just a littel bolt. i think thats what your talking about. but this is what i would do. disconnect the bottom hose. let everything poor out.connect the hose again. put fresh water in. not tap. fill it all the way up. with rad. cap open squeeze the hose for all the air bubbles to come out. u dont want air bubbles, it will couse more problems later. let the cun run an get to temp. after u do that. drain it all out like before. use a 50/50 mix and fill it back up. put that shit in u got an call it a day. the reason why use fresh water 1st because thats cleaning all the contamintes that might be in there. BUT MAKE SURE USE FRESH BOTTLE WATER, NOT TAP.
sorry for the spellin.
FastCrxVaWLude is offline
Old 01-06-2006, 08:16 PM
IRR0MPIBLE's Avatar
thanks for the input guys
Old 01-06-2006, 08:29 PM
glad to help
m4s4mur4
04-15-2008 08:09 PM
sive ick
02-11-2007 11:16 AM
IRR0MPIBLE
01-06-2006 10:30 PM
Quick Reply: Flushing radiator/cooling system?
