firing order and firing problem
Old 11-19-2010, 05:59 AM
streetmagic808's Avatar
streetmagic808 has disabled reputation
Default firing order and firing problem
i have a 94 EG hatch with a B18A1 LS motor i have in it and im having firing problems sometimes it will have a spark and other times it wont. the motor turning but its not firing someone told me it was the ignition module so i changed that last night and its doing the same thing and im trying to get this hatch on the road so i can stop driving a gas guzzler when im working every night. PLEASE HELP ASAP!!!! thanks Rob
streetmagic808 is offline
Old 11-19-2010, 08:04 AM
sleeperteg's Avatar
sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg
Default Re: firing order and firing problem
If you're looking for the firing order it would be 1,3,4,2.
Also check the coil and spark plugs
sleeperteg is offline
Old 11-19-2010, 08:16 AM
thanks. i forgot to mention that i changed them to last night when i changed the ignition module
Old 11-19-2010, 08:42 AM
management
boredom's Avatar
boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom
that firing order placement is all wrong. 1-3-4-2 is correct, but 1 is relative to the distributor cap. your number 1 should be towards the back of the dizzy cap towards the lower radiator hose.
boredom is offline
Old 11-19-2010, 09:09 AM
did it still nuttin
Old 11-19-2010, 09:52 AM
sleeperteg's Avatar
There should be some kind of marker on the dizzy for #1, and then after that plug them in a clockwise order
The dizzy in the picture is not necessarily going to look the same as yours, and most likely isn't.
Old 11-19-2010, 01:09 PM
Have you checked that the ignition module and ignition coil are getting power? Don't just say "the fuse looks good", go and check that you actually have power at the coil and module connectors.
Old 11-19-2010, 01:15 PM
oxidejunky's Avatar
oxidejunky has disabled reputation
is it throwing any cels
oxidejunky is offline
Old 11-20-2010, 03:21 AM
i took the 2 module to auto zone last night and they both failed so the guy that worked there tried a brand new one right off the shelf and that failed so i'm going to try some more places today.
Old 11-20-2010, 09:26 AM
I think there's a secondary lesson here about buying things like that from Auto Zone.
Quick Reply: firing order and firing problem
