f body question
Old 11-04-2009, 10:15 AM
RandomTask's Avatar
Default f body question
On a 3.8 2000 camaro,how is the quick disconnect on the slave cylinder supposed to work?
RandomTask is offline
Old 11-04-2009, 10:19 AM
VA
travisnd's Avatar
travisnd travisnd travisnd travisnd travisnd travisnd travisnd travisnd travisnd travisnd travisnd
Default Re: f body question
travisnd is offline
Old 11-04-2009, 10:21 AM
Fanboi
Cobra4B's Avatar
I'd assume like the quick disconnect on the slave on a C5... pull back the collar and it seperates.
Cobra4B is offline
Old 11-04-2009, 10:57 AM
RandomTask's Avatar
So I figured it out. Now I'm trying to separate the trans from the engine. Any tips? Two top. Bellhousing bolts suck.
Old 11-05-2009, 03:02 AM
RandomTask's Avatar
To update for future reference. I've used GM quick disconnects before. For the fuel systems, they have theese tools that wrap around the line, then you push into the fitting to seperate. The system on the fbody did not have any where to slide in the tool. Theres actually a small piece of white plastic on the hydraulic line side of the fitting. Take a screw driver to push this down as far in as possible toward the trans. After its all the way down, pull on the hydraulic line to seperate.
As far as the bolts go;
On the T56 on GT0's, you can simple seperate the trans from the bellhousing, then easily get to those bolts. Because the slave cylinder on the f-body is bolted to the back of the bellhousing and the slave cylinder lines come out the side, you can't do this. What you have to do is get a flex coupling on the end of the socket (on the top two bolts) and extension down. I suggest using a half inch. Reason being, 3/8" drive system was flexing too much and not applying all the torque onto the bolt.
Now i'm off to drop the completely blued flywheel off to the machine shop :ack:
cleanEK
03-20-2008 05:06 AM
cleanEK
10-22-2007 12:40 PM
MustB18
12-19-2005 11:47 AM
Fear
03-19-2004 10:00 AM
Quick Reply: f body question
