EP3 Transmission Help
Whats up guys, So over the past week i've been helping my brother replace a clutch in his 03 Civic Si. Everything seemed to go smooth other than bleeding the clutch because of the location. the bleeder screw is under the intake manifold which makes it a massive pain in the ass. anyways. I felt like i got pressure in the pedal, so we drove the car up the road.
it seemed to be fine but at the top of the road there was a small pop and then it would not move, it felt like it was in neutral. It feels like it goes into gear but nothing happens. any ideas where to start troubleshooting.
Thanks Guys
Thanks Guys
Re: EP3 Transmission Help
A pressure problem with the clutch would only give problems when the clutch is released. You've got a mechanical problem, not a hydraulic problem. Check the shift linkage very carefully if you had to remove or loosen it during the clutch replacement. Most of the things that are clutch related are usually failure to disengage instead of failure to engage, but there are still some things that can keep from engaging properly.
