engine will start but sputters occasionally 1995 accord
Old 02-17-2012, 06:44 AM
slowd16y8's Avatar
slowd16y8 has disabled reputation
Default engine will start but sputters occasionally 1995 accord
Ok let me start by explaining what I have here. I have a 1995 accord that has had a swapped f22b1 vtec installed (was already swapped when I bought it). I have found a bullfrog throttle body has been installed, the intake mani has been ported and polished, DC sports header, ApexI full exhaust. There is a possiblity that it has an aftermarket cam (we are not sure). I have had the head decked, valve job, cleaned. replaced the plugs and wires, timing belt, distributer, coil pack, water pump, tensioner, balance shaft belt, brakes, rotors, wheel bearings, ball joints, tie rod ends, thermostat, oil changed, radiator flushed and shocks in the front. Everything I have done has been over the past few days. All gaskets and seals have been replaced as well.
Now, we can get the car to start and it runs fine but every 3-4 revolutions it has a little stutter, but immediatly corrects itself. Now keep in mind I did the valve adjustment on it myself (which was a first for me) I'm sure that I didn't tighten them down too far but I'm sure they are more loose than need be. Since everything has been installed I know that the motor has only ran for maybe a total of 20 minutes.
Could the cam possibly be aftermarket,...if it is how do I find out, could this be the problem?
Could the timing be off? We have been through the timing belt about 7 times to make sure and I'm seriously wondering if the cam is aftermarket because we would either need to retard it or advance it to make the timing right at that point.
Thank you for any insight that you could possibly give in advance.
slowd16y8 is offline
Old 02-17-2012, 08:22 AM
Default Re: engine will start but sputters occasionally 1995 accord
Decking the head can change the cam timing.
Old 02-17-2012, 02:02 PM
slowd16y8's Avatar
Should I retard the timing or advance it if the decking would change the timing?
I found out that when the machine shop reworked the head they didn't check the valves to make sure they were good so I have to replace both intake valves on the #2 cylinder...for what I paid them I should have just had new valves installed. So far thats the problem that we have found. I will post back to let everyone know if there is anything else.
gs30094
08-09-2011 12:04 PM
bobbyspradlin89
01-05-2011 05:46 PM
efhatchlover
11-12-2009 11:45 PM
hondazccivic
12-19-2003 09:55 PM
WutupYo
03-20-2003 10:46 AM
Quick Reply: engine will start but sputters occasionally 1995 accord
