Engine not starting
Old 05-20-2004, 04:24 PM
swtch7's Avatar
swtch7 is an unknown quantity at this point
Default Engine not starting, please help!!!
Please help! This is the scoop, today i was driving down 64 when all of a sudden my car just turns off, all power is still there, but the engine just cuts off. The car is turning over but not starting. Its a 92 Civic Si, with 150,000 miles on it. I have put around 7000 on the car. I havent really had a chance to trouble shoot this issue just yet, but this is what I have done
I pulled the wires out and looked for any spark what so ever, and found none. So i took off the distributor cap and checked the leads, a little corroded, with some fine grit sand paper i cleaned them. Put the cap back on and still no spark. So im thinking posibly the coil or even the distributor could be bad. Does anyone have any suggestions or thoughts. I need to have this car fixed ASAP!!! thanks
swtch7 is offline
Old 05-20-2004, 04:30 PM
swtch7's Avatar
Default Re: Engine not starting
And I am positive its not a fuel problem
swtch7 is offline
Old 05-20-2004, 04:32 PM
Huntin Dropa ForLife
RPRacing's Avatar
RPRacing has disabled reputation
check your fuses(are they all there and not blown)
check the plug wires (how old are they)
check the coil (does it look burnt?)
check the ignitor (second to last resort)
change the dizzy
RPRacing is offline
Old 05-20-2004, 04:51 PM
swtch7's Avatar
thanks sucka, i forgot to mention that i checked the fuses, they are good. The wires im sure wouldnt hurt to be replaced, they are old. The coil didnt look burnt, but i only checked the side going into the cap. The car is at a friends right now, but ill check on the rest of it tomorrow. Thanks for the input!!!
swtch7 is offline
Old 05-20-2004, 05:04 PM
RPRacing's Avatar
no problem ,hope that helps
RPRacing is offline
Old 05-20-2004, 05:12 PM
i like prom.
urvtecs2slo's Avatar
just do a basic ignition system tuneup. it wouldnt hurt, and it might solve your problem.
urvtecs2slo is offline
Old 05-20-2004, 05:43 PM
Shortfuse's Avatar
Shortfuse is an unknown quantity at this point
Check your timing belt. The easiest way to check it is to have someone crank the motor while you watch to see if the rotor in the distributor turns.
Shortfuse is offline
Old 05-20-2004, 06:07 PM
Bitches get Stitches
sk8rmike's Avatar
i would put 100 down that your distributor went bad. the 92-95 dizzys are notorious for shitting out....either your coil or ignitor.
sk8rmike is offline
Old 05-20-2004, 06:47 PM
swtch7's Avatar
I know this is the wrong thread for this, but anyone selling a distributor for a 92 civic si? thank you everyone for your input!! ill let you know what it is in the comming days.
swtch7 is offline
Old 05-21-2004, 06:11 AM
corona connessuer
CHAHONDA's Avatar
replace your coil!!!
CHAHONDA is offline
Quick Reply: Engine not starting
