Engine Management
Old 01-24-2005, 11:02 PM
I have a 20 valve...
crxnfx's Avatar
Default Engine Management
Ok, here is a quick questions. I've been doing a lot of research on EMS and Fuel managements, since I have none, am running rich as hell and would prefer not to foul up the motor with a lot of unburnt fuel
So, for an LS, non turbo, what do you recommend. I was reading up on AEM's EMS but it seems to require just more than the box.
I've also been looking at SAFC's but does anybody have any before and after info; how did it run before, and now....
Also, I've also been looking into Hondata. Would it be worth it, or would it be easier to go to a plug and play system as opposed to a fully built hondata?
I of course know that answer to that "Hondata all the way" but just wondering if something else could take its place.
crxnfx is offline
Old 01-25-2005, 01:13 AM
StpH8n's Avatar
StpH8n is an unknown quantity at this point
Default Re: Engine Management
For the money and for your application i think the AEM EMS is way too much for what you need. I personally would recommend doing a uberdata/hondata type setup. I am running a chipped p28 setup and I love it. Im not running uber or hon, im running chrome but its the same basic concept. I have most of the tunability of a standalone and payed only a fraction of the cost (55 for ecu, 20 for chipping, 100 for dyno tuning).
So, my vote is a hondata/uberdata setup.
StpH8n is offline
Old 01-25-2005, 01:25 AM
riven282's Avatar
riven282 is an unknown quantity at this point
run uberdata.. the software is free and you can change anything you want. all you have to do is get your ecu chipped and if you look on h-t you can find people that will even chip the ecu for you if you are not good at electronics for `~75 then get a eprom burner for ~85 and yourset here check it out for yourself Uberdata
riven282 is offline
Old 01-25-2005, 02:15 AM
crxnfx's Avatar
I'm sorry if I gave you the impression that this was the run of the mill LS engine; its not.
crxnfx is offline
Old 01-25-2005, 02:16 AM
crxnfx's Avatar
I'll check it out.
crxnfx is offline
Old 01-25-2005, 02:21 AM
crxnfx's Avatar
well uberdata is out, you need an OBD1 car, and my engine is OBD0
crxnfx is offline
Old 01-25-2005, 05:39 AM
hybrid no more :(
Bert's Avatar
hondata and AEM both need at least obd1... hondata doesn't sell the old style stage 2/3/4 for obd0's...i also believe that these were only used w/ pr3 and pwo but not entirely sure... I converted my crx to obd1 because of all the headaches of obd0... i do know w/ an AEM EMS you can even use the obd0 distributor w/ the obd1 AEM EMS... all you have to do is change some settings from a 24 tooth distributor to a 16 tooth distributor...good luck w/ you setup..
Bert is offline
Old 01-25-2005, 06:09 AM
mini me on boost
mateo189's Avatar
mateo189 is an unknown quantity at this point
i have a OBD0-OBD1 jumper harness and 2 wire o2 sensor for sale...
mateo189 is offline
Old 01-25-2005, 11:18 AM
Wii
Retired OG
Wii's Avatar
Wii Wii Wii Wii Wii Wii Wii Wii Wii Wii Wii
Nothing can take Hondata place when it comes to dailey street driven. Its the best engine managment system out there for Hondas. But when it comes to hardcore weeken races at the drag strip, thats when AEM EMS steps in.
Wii is offline
Old 01-25-2005, 12:48 PM
junior1643's Avatar
junior1643 has disabled reputation
So for just moderate modifications to engine you should go with uber/hondata for OBD 1 and OBD 2 You should go with either the VAFC or THe EMS????
junior1643 is offline
Quick Reply: Engine Management
