Engine harness help
Old 03-04-2010, 04:52 PM
xCHRISx's Avatar
xCHRISx has a reputation beyond reputexCHRISx has a reputation beyond reputexCHRISx has a reputation beyond reputexCHRISx has a reputation beyond reputexCHRISx has a reputation beyond reputexCHRISx has a reputation beyond reputexCHRISx has a reputation beyond reputexCHRISx has a reputation beyond reputexCHRISx has a reputation beyond reputexCHRISx has a reputation beyond reputexCHRISx has a reputation beyond repute
Default Engine harness help
Hey, i have a 2000 Civic ex with a d16z6 in it.
it has the wrong engine harness so the engine light stays on and i think its running rich
Im trying to find the best engine harness for it but idk what to look for
or if there is something wrong because it used to be obd2 now its obd1, i think thats why the CEL is on
If someone could give me a link or something that would be great.
thanks
xCHRISx is offline
Old 03-04-2010, 05:42 PM
Default Re: Engine harness help
What ECU is it, and what engine is the harness from?
Old 03-04-2010, 06:01 PM
hondadude_rudo is an unknown quantity at this point
you should always use the harness from the car your putting the engine in, and its probably throwing a code for the crank fluctuation sensor thats mounted on the oil pump cover of the stock engine, but dont exist on the z6 engine. not to mention the fact that having that engine in your car is technically illegal in va since the law states that any engines must be the same year as, or newer than the car they are going into. but then again, unless you live where they smog test and stuff, you dont have to worry bout that lol.
hondadude_rudo is offline
Old 03-04-2010, 06:09 PM
Crank fluctuation sensor is only a problem if the ECU is OBD2 obviously. Not enough information yet.
Old 03-05-2010, 05:58 PM
xCHRISx's Avatar
How do i know what the ECU is?
It should have P28 and OBD1
but i dont think it does
xCHRISx is offline
Old 03-05-2010, 06:00 PM
ECU is in the passenger kick panel, there is a bar code sticker on one edge of it. The ECU code is part of a longer part number.
Old 03-05-2010, 06:41 PM
xCHRISx's Avatar
ill check it tomorow
but thanks, ill pm you the answer
xCHRISx is offline
Old 03-06-2010, 06:04 PM
Post in this thread instead of PM'ing, then more people can help.
Old 03-08-2010, 06:04 PM
Ramey Built
JB@RameyBuilt's Avatar
JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt
Like fabrik8 said, post the ecu code in the thread. How do you know the engine harness is wrong? Have you tried pulling the codes? If so, what codes did it give you? Not knocking your intelligence but if you're not sure how to pull them here's how.
http://honda-tech.com/showthread.php?t=878010
JB@RameyBuilt is offline
d16z6crx
Engine / Exhaust / Drivetrain
01-28-2010 03:39 AM
gotboosthatch
Want to Buy / Trade ARCHIVE
12-06-2008 02:54 PM
diggity dave
04-22-2006 03:27 PM
Quick Reply: Engine harness help
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
