Eg coupe ls swap problems
Old 10-26-2011, 06:31 PM
pickupguy89's Avatar
pickupguy89 has disabled reputation
Default Eg coupe ls swap problems
Ok so i picked up a 93 eg coupe with b18a1 and jdm head the other day, and the cel is on and throwing 3 and 6 codes.
It doesnt like to be cold started has a hard time staying running
and when i start it, it will start and idle low like it wants to shut off then go back up after its warmed up
3 is MAP sensor
and 6 is ECT (engine coolant temp) sensor.
so a buddy gave me a new MAP sensor and replaced it, unhooked the battery for awhile to reset the code.
still came on as map sensor
and the ect connector was still from a d series so i swapped the connector wired it up and still has code 6
and will still run like before.
anybody know what to do?
pickupguy89 is offline
Old 10-27-2011, 02:43 AM
wright's Avatar
Default Re: Eg coupe ls swap problems
I would start by looking at the wiring. I found another thread that a guy had the same problem and it was the wires going to the MAP causing the issue.
wright is offline
Old 10-27-2011, 08:10 AM
Sounds like a wiring problem. Grab a multimeter and start checking continuity.
Old 10-27-2011, 08:11 AM
yaaat.
ryanherington's Avatar
Might wanna explain some more, this IS vadriven ya know.
edit: that's what google is for.
ryanherington is offline
Old 10-28-2011, 04:07 PM
ok well i found the map sensor problem, i found a exact connector just hanging and plugged it in n reset the ecu n its off
now im trying to find out the engine coolant temp code now.
im about to change out the sensors and see if its that.
if anybody has any input on this plz help. thanks
Old 10-28-2011, 06:58 PM
ok so i found the problems for both.
the dude who did the swap before me had the wrong wires connected to them,
found other connectors hanging out plugged em in and cleared the code and now all good n runing perfect
but......now
i took it out just now drove it no codes, then goosed it to about 5k and the cel came on
i jumped it and code 41 came up, primary 02 sensor heater.
could it be a bad 02 sensor? never came up before when i was hard on it
Old 10-28-2011, 08:40 PM
2egcivics's Avatar
2egcivics has disabled reputation
i have the same problem and its not the bad of a problem to have or car will just runn a lil rich in warm up,thats all
2egcivics is offline
Old 10-29-2011, 03:12 AM
as in what problem? code 41?
Old 10-29-2011, 08:32 AM
2egcivics's Avatar
yep i have the same code on my 93 4 door with an ls swap and it just runns a lil rich when its warming up
Old 10-29-2011, 12:12 PM
The ECU is probably running properly now that you have cleared the faults, which is why the O2 sensor is showing up all of a sudden. You know there were other wiring problems, so I would check the O2 sensor wiring too. If you find out that you need a new sensor, get a OEM Honda sensor instead of an aftermarket sensor from Autozone. I know the Honda sensors are more expensive, but they actually work properly.
The guy you bought it from must have been pretty intelligent if he messed up an LS swap in an EG. It doesn't get any easier than that when it comes to engine swaps.
Quick Reply: Eg coupe ls swap problems
