Ef civic turbo need help making fliter fit on turbo
I have a 91 civic DX with a JDM D15B swap and a garrett turbo set up. I'm trying to make a filter fit on the turbo inlet but there is no room between the inlet and the radiator fan. should i get a slim fan or does someone make a piping kit? any help would be great guys.
Re: Ef civic turbo need help making fliter fit on turbo
Yes, piping is usually put between the turbo and the filter, then you can put the filter wherever you want, (preferably not where the filter will get suck in hot air from the radiator and get heat soaked from the engine block).
Is your turbo inlet pointing at the radiator for some reason?
