ef b18 starting problem
Re: ef b18 starting problem
you need to check the wiring on the ecu plug, There are 4 wires that have to be swaped around. The crank angale sensor is in the wroung spot You can get the diagram on ff-squad.com. This might help you out. If problem is still ther feel free to call me at 540-368-0030 ask for Jon.
N/A
ive noticed sometimes when i try and start the car then turn the ignition off and take the key out the lights in the dash (ex.brake, seatbelt, oil, etc....) are still on but realy dim and the ecu is still blinking the code. i have to disconnect the battery to turn it off.
