ECU code problem
my ls swap is throwing the "cyp" code.I looked it up and all it says is a bad sensor,but it dont say which one.I need to figure this out,any suggestions?
Re: ECU code problem
how are you reading these codes?
CYP Sensor (Cylinder)
defective circuit or unplugged / defective sensor Check it out. If its ok, check your timing, and make sure you dont have your air intake sensor and IACV mixed up. |
thats the the code,thanks ill try that but i no the timing is perfect so it has to be a sensor
It could be the wiring too, don't assume the sensor is bad yet. With an engine swap I always assume it's the wiring first and troubleshoot from there. You'd do that too if you'd see the swap wiring atrocity that I've seen.
CYP is cylinder 1 position sensor if I remember correctly. |
problem solved thanks for the input.close thread
| All times are GMT -8. The time now is 06:43 AM. |
