-   -   ECU code (https://www.vadriven.com/forums/tech-talk-9/ecu-code-265/)
one pnt 8 hatch Nov 5, 2002 09:27 PM
ECU code
my check engine light comes on after drivin for ahwile flashin a code 14 and 17 what do they mean and what is the problem plus my tranny makin a funny noise when i let the clutch out i think its the throw out bearing for the clutch but i dont know someone give me a hand here
brcivic411 Nov 6, 2002 05:08 AM
code 14: Idle Control System Malfunction (Bad IAC valve, bad fast thermo valve, Throttle Body)
code 17: Vehicle Speed Sensor circuit (Short or open in VSS circuit, bad VSS)
one pnt 8 hatch Nov 6, 2002 07:03 PM
kool thanks
crxnfx Nov 7, 2002 11:15 AM
do you mind if I jump on your band wagon? I am throwing a code 2, the idle is fine but when throttling up it kinda skips, hesitates, and in the high RPM's- forget it! Any ideas? just had the bitch tuned, new timing belt, new cap, need to get a new rotor....
thanks!
brcivic411 Nov 7, 2002 12:02 PM
code #2 - problem with secondary O2 sensor. Sounds like your car is running in 'limp' or 'safe' mode.
Try resetting the ecu and if the code comes back, you might need to replace your secondary O2 sensor.
btw, here's a link to all the CEL codes:
http://www.c-speedracing.com/faq/05.html
chad Nov 7, 2002 01:51 PM
this may be a dumb question , how do u reset an ECU ?
one pnt 8 hatch Nov 7, 2002 01:54 PM
dont u take off the postivie end of the battery
Fabrik8 Nov 8, 2002 01:33 PM
A surefire way to check if it's running in safe mode is a loss of power and it'll run full rich all the time, because it is running off of the minimal sensor inputs, just tach input and throttle position...
BlueTegB18A Nov 8, 2002 01:49 PM
Just disconect your battery for a little bit.
20psi B18c1 Nov 8, 2002 01:50 PM
dam..dont have to leave out for an hour..pull fuse leave out for 30 seconds and put it back in...
by the way i have a brand new IACV for sale if you need one..200 bucks from acura ..holla at me and we can talk
