ECU code
Old Nov 5, 2002 | 09:27 PM
one pnt 8 hatch's Avatar
The Dune Coon
one pnt 8 hatch is an unknown quantity at this point
Default ECU code
my check engine light comes on after drivin for ahwile flashin a code 14 and 17 what do they mean and what is the problem plus my tranny makin a funny noise when i let the clutch out i think its the throw out bearing for the clutch but i dont know someone give me a hand here
Old Nov 6, 2002 | 05:08 AM
brcivic411's Avatar
brcivic411 is an unknown quantity at this point
code 14: Idle Control System Malfunction (Bad IAC valve, bad fast thermo valve, Throttle Body)
code 17: Vehicle Speed Sensor circuit (Short or open in VSS circuit, bad VSS)
Old Nov 6, 2002 | 07:03 PM
The Dune Coon
kool thanks
Old Nov 7, 2002 | 11:15 AM
crxnfx's Avatar
I have a 20 valve...
do you mind if I jump on your band wagon? I am throwing a code 2, the idle is fine but when throttling up it kinda skips, hesitates, and in the high RPM's- forget it! Any ideas? just had the bitch tuned, new timing belt, new cap, need to get a new rotor....
thanks!
Old Nov 7, 2002 | 12:02 PM
brcivic411's Avatar
code #2 - problem with secondary O2 sensor. Sounds like your car is running in 'limp' or 'safe' mode.
Try resetting the ecu and if the code comes back, you might need to replace your secondary O2 sensor.
btw, here's a link to all the CEL codes:
http://www.c-speedracing.com/faq/05.html
Old Nov 7, 2002 | 01:51 PM
chad's Avatar
no longer a moder8r
chad chad chad chad chad chad chad chad chad chad chad
this may be a dumb question , how do u reset an ECU ?
Old Nov 7, 2002 | 01:54 PM
The Dune Coon
dont u take off the postivie end of the battery
Old Nov 8, 2002 | 01:33 PM
A surefire way to check if it's running in safe mode is a loss of power and it'll run full rich all the time, because it is running off of the minimal sensor inputs, just tach input and throttle position...
Old Nov 8, 2002 | 01:49 PM
BlueTegB18A's Avatar
BlueTegB18A is an unknown quantity at this point
Just disconect your battery for a little bit.
Old Nov 8, 2002 | 01:50 PM
20psi B18c1's Avatar
holla at ya homies
20psi B18c1 is an unknown quantity at this point
dam..dont have to leave out for an hour..pull fuse leave out for 30 seconds and put it back in...
by the way i have a brand new IACV for sale if you need one..200 bucks from acura ..holla at me and we can talk
hatchn1.6
Oct 27, 2008 12:57 PM
kaltares
Jul 28, 2008 09:02 AM
mini-meturbodx
Oct 10, 2005 09:48 AM
BoOsted
Jan 20, 2005 03:33 PM
jc blanco
Aug 19, 2003 09:54 PM
