eacv problems maybe?
Old 07-31-2010, 02:34 PM
jdmperspective's Avatar
jdmperspective has disabled reputation
Default eacv problems maybe?
Hey i have a 1994 honda civic with a z6 swap in it. The problem is when i accelerate it will start to jerk or hesitate at around 1500 to 2000 rpms. The check engine light is on for the eacv. I might know where that is located but im not completely sure. This is the first time i have had this problem. Should i just clean it or what. If yall have answers that would be great. Thanks
jdmperspective is offline
Old 07-31-2010, 02:56 PM
baller/dickbutt#69
nftuatn's Avatar
Default Re: eacv problems maybe?
iac maybe?
nftuatn is offline
Old 07-31-2010, 03:02 PM
yeah but i dont think the iac makes the car jerk back and forth.
Old 07-31-2010, 05:37 PM
I think you're talking about an IACV. And no, it won't cause jerking, because it's only function is to bypass air across the throttle plate in order to regulate idle. The amount of air it can actually flow is nowhere near enough to cause off-idle drivability problems. It's more likely you have a problem with your MAP, TPS, or O2 sensor.
Old 07-31-2010, 05:59 PM
yeah the IACV and thought so. Im thinkin its the tps. Im just confused with the fact that my light is on for the eacv. Dont really know the things that happen when those troubleshoot.
Old 07-31-2010, 07:30 PM
If you have an IACV check engine light (EACV is the same thing by a different name), you have an IACV problem. That's not going to be the problem with the jerking, etc., but you should get the IACV fixed also because that can cause idling problems and other things.
Actually, check really carefully to see what's plugged into what. I think I remember that there are two plugs which can be plugged into each others locations, so the plugs may be swapped. I can't remember which two plugs that is, but it's worth double checking everything just for good measure.
Old 07-31-2010, 08:21 PM
alright the iacv has 2 plugs on the bottom of it which connect to hoses. ill check and make sure those arent swapped. If not then its most likely the tps. Ill have to look into it i never fixed a tps problem. Thanks
Old 08-04-2010, 06:05 AM
12345r's Avatar
12345r has disabled reputation
hes talking about the map and tps plugs they can be mixed up bc there the same thing
12345r is offline
Hybrid AWD
12-29-2009 10:03 PM
lighterfire
04-24-2007 08:47 PM
nickyroo
05-25-2003 10:17 AM
falling animals
01-21-2003 09:22 AM
MGBRaceman
01-13-2003 03:43 PM
Quick Reply: eacv problems maybe?
