Dumb Car Audio Question
Old 03-05-2009, 08:31 AM
Troll & Run
ShawnD's Avatar
Default Dumb Car Audio Question
Is it possible to hook two amplifiers upto just one set of pre amp outputs?
-Thanks
ShawnD is offline
Old 03-05-2009, 08:35 AM
Digital Life
83Stang5.0's Avatar
Default Re: Dumb Car Audio Question
It can be done a few ways, I dont think any are really a good idea though.
If an amp has in and out rca's then you can do it that way, but if you want to take the speaker output straight to rca input of a second amp, I'm pretty sure it would sound like super shit.
Maybe splitting the rca's before the amp so you have 2 sets from 1, but bridging the 2 amps together to a sub would be bad more than likely too. Unless the sub is some godlike quality and RMS rating.
83Stang5.0 is offline
Old 03-05-2009, 08:49 AM
SpeedJunkie's Avatar
SpeedJunkie SpeedJunkie SpeedJunkie SpeedJunkie SpeedJunkie SpeedJunkie SpeedJunkie SpeedJunkie SpeedJunkie SpeedJunkie SpeedJunkie
SpeedJunkie is offline
Old 03-05-2009, 09:17 AM
Yes, you can use an RCA splitter. It's done all the time. It's a good idea to split the RCAs behind the head unit, instead of where the amps are. That way you have two cables running to the amps from the dash, and if you get a better head unit with more than one set of RCA outputs, you already have the cables run and can just remove the splitter and go.
Old 03-05-2009, 09:20 AM
I think we all meant splitting it right after the HU, if it wasn't clear I am sorry.
Old 03-05-2009, 09:25 AM
I understand. My point was that it's more convenient to do it right behind the head unit and then run two RCA cables to the amps instead of running one RCA cable to the amps and then splitting it there. Where it's split doesn't matter except for convenience in the future.
black6gen
04-27-2006 10:42 PM
UNCLEBENZ
11-30-2005 11:24 AM
E36DJ
12-06-2004 01:03 PM
bye
08-27-2004 09:02 AM
1BadSC300
01-10-2003 09:41 AM
Quick Reply: Dumb Car Audio Question
