dsm engine swap
Old 12-24-2003, 05:44 PM
why'd you break it?
2gdsm gst's Avatar
2gdsm gst is an unknown quantity at this point
Default dsm engine swap
what do i have to do to put a first gen 4g63t in my 95 gst, or is it bolt in and plug up directly? ive been told different things and need to know this asap
2gdsm gst is offline
Old 12-24-2003, 07:21 PM
RIP Chris Schader
g S x's Avatar
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
here
http://magnusmotorsports.com/1g2g.asp
g S x is offline
Old 12-24-2003, 07:39 PM
No Name Who?
Ninety7GSX's Avatar
Ninety7GSX has disabled reputation
Its fairly easy if you have the necessities.
The mod to the timing belt cover they are talking about is to clear the 2g motor mount, you must cut it out.
I used a bench grinder for cutting the motor mount.
You can use a 1G coil instead of playing with the 2g and making it work. I just swap the wires over or just bolt the 2G coils to the 1g mount. The coils don't bolt directly but if you look at it it will go.
The MDP you can leave unplugged (to vacuum) on some cars. I just leave them sit under the 1g plenum if it codes hook it to vacuum.
The transistor mount I bolt it to the top of the intake plenum with just one bolt. Or you can pull the wires out of the harness more and mount it where you can find.
The only thing about the swap I don't like is the fact that the tensioner tool can't be used anymore.
I think thats about it.
Ninety7GSX is offline
Old 12-24-2003, 07:45 PM
RIP Chris Schader
g S x's Avatar
what tensioner tool, i use a screwdriver
g S x is offline
Old 12-24-2003, 08:01 PM
why'd you break it?
2gdsm gst's Avatar
guys i appreciate the help. ive been trying to figure out wether or not to rebuild my 1g block or keep trying to find a 2g block
Old 12-24-2003, 10:14 PM
RIP Chris Schader
g S x's Avatar
g S x is offline
Old 12-25-2003, 02:42 PM
No Name Who?
Ninety7GSX's Avatar
The one that screws into the back of the motor mount through the timing cover. That bitch saves tons of time if you have to do something like cam gears or anything that doesn't require removal of the timing cover.
Sounds like he already has a spare 6 bolt.
Old 12-26-2003, 04:09 AM
Colt63t's Avatar
Colt63t is an unknown quantity at this point
I may have some of the 1g parts you may need. pm me if you need it.
Colt63t is offline
dfoxengr
Want to Buy / Trade ARCHIVE
18
02-19-2008 09:29 AM
Spindrift
12-03-2005 02:28 PM
Quick Reply: dsm engine swap
