down to 1 problem with mini me swap
Old 12-06-2009, 10:35 AM
CDUB1980's Avatar
CDUB1980 CDUB1980 CDUB1980 CDUB1980 CDUB1980 CDUB1980 CDUB1980
Arrow down to 1 problem with mini me swap
when i step on the gas the car takes a really long time to kick in. starts of like really really slow then everything kicks in like a shot of nos. also when i get to stop signs and lights the car starts bogging down or stalls.
Anyone know whats going on? I think it has to do with throttle cable and kick down cable. if not maybe timing is off????
CDUB1980 is offline
Old 12-06-2009, 10:36 AM
Works on S2000's.
C Ory's Avatar
C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory
Default Re: down to 1 problem with mini me swap
TPS?
C Ory is offline
Old 12-06-2009, 12:02 PM
CDUB1980's Avatar
see whats funny is everything was working on my car before i replaced the bottom end. I will check the TPS do you know how many volts it sapposed to read.
CDUB1980 is offline
Old 12-06-2009, 03:07 PM
johncarlito's Avatar
johncarlito has disabled reputation
is it even showin a tps code ???? check your code ?
johncarlito is offline
Old 12-06-2009, 03:15 PM
Team Ultraspeed
Do Work's Avatar
Do Work has a reputation beyond reputeDo Work has a reputation beyond reputeDo Work has a reputation beyond reputeDo Work has a reputation beyond reputeDo Work has a reputation beyond reputeDo Work has a reputation beyond reputeDo Work has a reputation beyond reputeDo Work has a reputation beyond reputeDo Work has a reputation beyond reputeDo Work has a reputation beyond repute
timing belt is off by a tooth? had the same problem with a b16 after i did a belt change once.
Do Work is offline
Old 12-06-2009, 03:56 PM
slammed's Avatar
slammed has disabled reputation
sounds like the timing to me, where is it currently set at?
slammed is offline
Old 12-07-2009, 10:20 AM
...pulls trailer!!!
TurboEG8's Avatar
TurboEG8 TurboEG8 TurboEG8 TurboEG8
maybe vacuum leak
maybe tps is not set right
are the bolts in the tps oem???
TurboEG8 is offline
Old 12-12-2009, 05:53 AM
CDUB1980's Avatar
It was timed at top dead centered zeroed out.
CDUB1980 is offline
Old 12-12-2009, 09:08 AM
backtoarms's Avatar
backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms
Sounds like timing to me as well.
backtoarms is offline
dohc90zc
08-22-2007 05:08 AM
dohc90zc
08-22-2007 04:25 AM
ak1ra
07-20-2007 10:56 PM
VASlim23435
04-21-2004 11:33 AM
TMRCIV
12-10-2003 06:40 AM
Quick Reply: down to 1 problem with mini me swap
