do i need motor mount inserts?
i have a 99 civic dx with a stock d16y7. whenever i give the car gas the shift lever moves(not vibrates). it "wiggles" i guess you could say. it also is ver hard to get into reverse and it makes switching gears harder sometimes. i was told i need motor mount insersts and dampers. i just wanted to run it by all of you guys to see what you think. thanks
Re: do i need motor mount inserts?
no. you need new mounts
and what were you doing to a 99 to make it need new mounts so soon with a stock engine? If the motor is moving excessively you need new mounts how hard is this shit |
I agree with (F-) buy new mounts and inserts and you should be fine from there. Unless you want to be cheap you might be able to get away with just inserts
Originally Posted by (F-)
(Post 3203009)
and what were you doing to a 99 to make it need new mounts so soon with a stock engine? If the motor is moving excessively you need new mounts how hard is this shit i actualy just got the car a few months ago and just started to drive it 3 weeks ago. it's done it since i've had it but it's slowly got worse. :( |
Originally Posted by ACCORDKID
(Post 3203505)
thanks.
