"DA" integra Front calipers and rotors on 89 crx si?
"DA" integrateg FRONT calipers and rotors on 89 crx si?
if they fit then it should be a cheap brake upgrade, right? granted not a big diff. but enough to make a diff. I tried search and could only find stuff on the rears.
is this a direct swap? Will i run into porportioning (sp?) problems? is it even worth doing for 25 bucks?
Boner Jams
i thinkn that civic brake upgrades are cheaper than teg, as for rear swap us the main part of it as in main arm with the brake part attached to it (oh 90-93) use your stock LCAs and other control arms. you will need to get the portioning valve from a teg or crx with disk brakes
