Da b20 swap need help
Just got a b20 for my 91 integra just need to know what imma need to complete the swap with ls trans such as harness computer and any other parts immanneed or switch on it please help
11B3P
Re: Da b20 swap need help
Google is your friend... Seriously.. Is this a B20Z or JDM? High compression, low? Any why an LS trans? Terrible combo IMO... I dropped a JDM B20B High Comp in my EG with a GSR Trans and its nice.. next is going to B20V probably.. If you have any questions let me know.. I run a P75 ECU OBD1 and used the mounts from the EG, B series axles, Is the intake the tall intake or short? You can use the short intake as long as the box is not on top. Need more info on what you have and then we can go from there..
And Holy Hell thats a lot of Neg rep!
peaches
^..WHAT DID YOU JUST SAY..i do not care. none of it was even close to the answer of the question at hand .. you sir have no idea EDIT:O yea turn your rep on
to the op...it is a direct swap just use the intake manifold and every sensor from the Ls on the b20..it so easy a caveman can do it
11B3P
edit, oh and Thanks.. did not see that you had to turn it on..
peaches
^^true alot of people do not run the ls trans. What I got from the OP's post is that he has a "da" integra. so i figure he has everything and all he wants to know is what to do. which is pull the intake manifold, header and trans off and install it all vice versa but with the b20
11B3P
Thanks guys first time with b series it is a b20z and ls trans is only cause need to do swap quick and don't have money for trans right now I heard it should go in pretty easy just gotta find computer the car is ob0 it is just the motor with stock intake and headers I have a skunk 2 intake to put on it and gonna change headers anyways just tryna learn screw the negative feedback doing this all myself just asked for help not there opinions
