d16a6 with 95 ex tranny.. hydro to cable help!
I Am rebuilding my crx And im using a 95 ex tranny. Wht all will be needed to convert from hydro to cable? Will a need a differnt trans mount And which conversion kit is better?
Re: d16a6 with 95 ex tranny.. hydro to cable help!
If you want to put a trans in your CRX the right way then you need a cable ZC trans and halfshaft plus 90-93 Teg axles. Before putting the axles in: pop out the big washer on the inside of the hub. Now you have an equal length axle set up on a crx correctly.
H motors has the trans and halfshaft. I did this mod on my crx and I love it. Everything fits together and looks factory. Less torque steer
You're totally right. There just is not enough D series to go around . . . soon they'll all be gone.
D's are cheap and easy. And if OP wants his shit right he'll listen to me. Plenty of CIVIC/CRX ZC transmissions availible from JDM disrtributors. The D16A6 also has the bolt holes already tapped for the ZC halfshaft stock.
I already have a hydro trans fellas and I plan on using it instead of wasting my money. that's why I asked what kit was best.. I plan on using a cable to hydro conversion and I just wanted to know which kit was legit and straight fwd..
wheelspin
Engine / Exhaust / Drivetrain
03-29-2011 06:33 PM
JdmNugget
11-05-2009 06:23 AM
